pt cruiser fuel gauge not working properly
Old 09-27-15, 02:07 PM
I have an 01 PT Cruiser. when you turn the key on, the gauge goes to half full, stays there for a few seconds and then drops to empty. I have replaced the fuel pump and it is still doing the same thing.
Old 09-27-15, 03:17 PM
From what I've been reading it appears to a sender issue. You changed the pump. Did you change the entire in-tank assembly including the sender and the pump ?
Old 09-27-15, 05:11 PM
changed the whole assembly. did a resistance check on the new one and old one and both senders check good
Old 09-27-15, 06:52 PM
NJT's Avatar
NJT
NJT is offline
Does that instrument cluster use 'stepper motors'? Could be a bad one.
Old 10-05-15, 08:31 PM
it uses stepper motors, are they replaceable and where would i get one
