Reduced Engine Power
Old 10-26-15, 06:17 PM
My 2004 trailblazer,a couple of days ago displayed "reduced engine power" on the dash. The truck started sputtering/idling erratic,it also drives about 10 miles an hour max....also after I shut it down and crank it up again it revs really high and drops down to a shaky idle. Please help.
Old 10-26-15, 06:39 PM
ukrbyk's Avatar
Received 5 Votes on 5 Posts
Tune up due. Spark plugs, wires, air filter. Run Seafom through gas tank to clean passages.
Old 10-26-15, 06:43 PM
Received 6 Votes on 6 Posts
probably has codes stored in the pcm that will need to be read with a scanner to determine what the problem is probably suggest you see your local dealership for diagnosis.
Old 10-26-15, 07:16 PM
iceman681's Avatar
Received 2 Votes on 2 Posts
sorry to say its time for a throttle body. these use a drive by wire system. and what happens is a gear or sensor goes bad in the throttle body causing it to default to an idle. very very common. they have recalls out for newer models, i dont believe they did it for older years.
Old 10-27-15, 05:30 AM
Received 1 Vote on 1 Post
Have the trouble codes read. They will tell you what you need to know.
Old 10-28-15, 07:20 AM
Go to Autozone , O'Reilly , etc & they will read the codes for free .
If it is the throttle body , you may get buy with buying a spray can of cleaner & cleaning it .
But see what the codes say .
These " fly by wire " systems are a " solution in search of a problem " . And a way to sell expensive parts . :-(
God bless
Wyr
