94 crown vic sputters when first starting out
Old 10-30-15, 05:33 AM
Cool 94 crown vic sputters when first starting out
i have a 94 crown vic that has 120,000+ miles and is a good car, runs and drives well, except it tends to sputter when first starting out in it. there is also an occasional showing of the check engine light?
Old 10-30-15, 05:38 AM
Get the codes read & go from there .
God bless
Wyr
Old 10-30-15, 11:11 AM
suspect the sputtering is probably ignition related maybe plug wires maybe a spark plug would probably change them if its been awhile since they have been done.
once you have the codes read then you may have some idea of what is causing it to come on could be a lot of things but is probably not related to the sputtering, egr flow issue due to carboned up intake passage was a common problem with these models If I remember right.
Old 10-30-15, 07:03 PM
CasualJoe's Avatar
Should we assume this car has a 4.6L V-8? Is the sputtering more pronounced in wet weather or does it happen all the time?
