2005 Ford Taurus SE Strut and Spindle Replace
Hey,
My Taurus steering wheel was vibrating an awful lot and I took it to Mr. Tire to have the wheels balanced.
They told me that the strut might be bent and is sitting crooked and that I have a bent spindle.( both on the right side)
I looked at my car and looking at the right side strut there is a little plastic rubber piece that does sit lower and closer to the tire then the left side.
Is there anyway to know if the strut and spindle are truly bent?
Do I need to replace both spindles?
I looked online and it said the spindle is the CV Axle? is that correct? I cant just replace a spindle?
I looked online and 1Aauto has a video on how to do it. but they used a lift and I don't have a lift. is this job doable without a lift?
Thanks
Thanks
unless bent severely you would need to put on alignment rack to tell. Spindle is outer cv joint. bearing are in hub assy, What they said does not make sense to me. Maybe did not explain it well to you.
The only rubber piece in a strut is dust boot. Dust boot covers - or should cover - impact dampener, a urethane donut sitting right on strut shaft. Strut also has 2 coil insulators, lower and upper. So I am not sure what you talking about.
Spindles are EXTREMELY strong. They are one of the main front suspension strutural pieces. To bend spindle you either had to seriously hit it or.... well, I have my opinion on that particular make quality, so I'll let it be.
But yes, I have seen bent steering knuckles. After car wreck.
OP, if I were you, I'd take that car to a suspension pro for inspection and ask them to show their findings - if they find any. Mr Tire will not qualify on my books as suspension pro. You need frame and suspension shop. Like we have Vic's frame here.
Bent strut? I seen those too, but they normally do not function well, as piston gets jammed inside the tube.
Sounds like - if it's all true - someone either hit a major pothole or curb or car was in a wreck
