Mazda 3 2006 ODB Code P0455, P2187, P0442
Old 12-05-15, 03:32 PM
Hi, I have a Mazda 3 2006 which read the following:
About a week ago: (p = pending)
p0455
P2187
P0455 p
P2187 p
A couple days ago:
P2187 p
Tonight:
P2187
P0442 p
P0455 p
P2187 p
Also had problems starting the car after filling with Gas tonight.
I'm assuming the issue is a purge valve? If so, any easy way to test a purge valve without vacuum? Seems to be the only way I could find online.
Old 12-06-15, 06:44 AM
the_tow_guy's Avatar
Received 29 Votes on 23 Posts
So folks won't have to look them up:
P0455 Evaporative Emission Control System Leak Detected (gross leak)
P2187 Sys Too Lean at Idle Bank1
P0442 Evaporative Emission Control System Leak Detected (small leak)
I think I would first look for a broken/disconnected hose anywhere in the system (gross leak). I'm not sure that a defective purge valve would throw a "leak" code, although the idle lean code could indicate it's stuck open.
Might also replace the gas cap. Probably a long shot there, but have been known to cause evap codes. Looks like the purge valve runs about 50 bucks, so not really a good place to just toss a part.
Side note question: Do you routinely round up the fill when you're gassing or do you stop at the first "click"?
Old 12-06-15, 06:55 AM
ukrbyk's Avatar
Received 5 Votes on 5 Posts
OP, here's best site for you:
http://www.obd-codes.com/trouble_codes/
You can also link to Mazda specific situations off it. Otherwise, Mazda forum is always the best place.
