Can I adjust clutch engagement position in Accord 2000?
Old 12-29-15, 12:12 PM
C
Hi!
Yet another problem with my old Honda Accord 2000 (manual, 4cyl, sedan LX). Thanks for all the previous help here!
My clutch disk began slipping. Before I replace it, I wonder if I can improve things with adjustment. I have this car since 2007, went from 93K to 160K, and the clutch was always very "high" meaning that I had to release the pedal almost all the way before it would begin engaging. Now it began slipping but I wonder if it is not just the disk but something not adjusted properly, I think it should engage around the middle of the pedal play but it never did.
I have the Haynes repair manual but it is not clear from it: it suggests adjusting the pedal height (not it) and the pedal freeplay (also not it I don't think).
Can I adjust the pedal position where the contaact between the disk and the engine begins? Move it closer to the middle of the way between fully pressed and fully depressed?
Thanks!
Old 12-29-15, 12:44 PM
Received 1,412 Votes on 1,306 Posts
Is it a cable driven clutch mechanism or hydraulic ?
Old 12-29-15, 03:48 PM
C
It is hydraulic. Does it help me or hurt me?
Old 12-29-15, 03:57 PM
chandler's Avatar
Received 6 Votes on 6 Posts
Hydraulic will have no adjustment. Sorry. Make sure the system is completely bled properly and filled. It may help, but no adjustment. Sounds as if you have a clutch plate that is worn out.
Old 12-29-15, 05:20 PM
C
Thank you, PJMax and chandler.
Old 02-08-16, 09:53 AM
C
It looks like I'll be replacing the clutch disk, either by myself or at a shop, not sure yet. I'll open a separate thread about that.
Thanks!
