01 ford escape
Old 01-07-16, 12:01 PM
01 ford escape
My wife was driving and suddenly the power steering went out, she said it was hard to turn and then she drove for a little bit and then it just went out on her.and her check engine light came on. It would crank over a little bit then not at all wouldn't start. Changed the plugs to try. Found oil in the intake and put some oil in it because it was low. I can't figure out the issue. Any help????
Old 01-07-16, 01:05 PM
the_tow_guy's Avatar
Sounds like it threw the serpentine belt. Check that?
Old 01-07-16, 02:41 PM
ukrbyk's Avatar
Is that a timing belt engine? Oil in air intake points towards timing being off and valves not opening/closing when needed.
Old 01-08-16, 05:33 AM
I checked, Igor, and it's a timing belt engine. Can't see a correlation between that and loss of power steering while engine still running though.
Old 01-08-16, 11:35 AM
Gunguy45's Avatar
Super Moderator
Hmmmm...never saw the engine mentioned by the OP. Pretty sure the V6 has chain and the 4 a belt. My 2001 Tribute V6 (same as an Escape basically) was a chain.
Old 01-08-16, 03:32 PM
The 2.0L 4 cyl is belt. I didn't look for other engine options.
Old 01-09-16, 06:04 PM
ukrbyk's Avatar
power loss is simple - loss of engine power leads to loss of power steering. Don't forget who was driving. feedback may be a bit askew
