02 pt cruiser dead?
Old 01-24-16, 12:03 PM
02 pt cruiser dead?
Hi all,
I have an 02 pt cruiser with 50k miles on it. Had to have it towed to garage yesterday. To cold in NY here to look at it. Here is what happened, any ideas. Started car put it in drive in the driveway and immediately stalled. Started agian let it warm up a minute. Put it in drive drove about 50 feet out into street and it died agiaan. Started it up put it in reverse and it died again. This time when i went to start it when Key was turned the car was completely dead. No turnover and no clicking of solenoid. Nothing and all lights are on so battery is fine. Let it siit for an hour and then tried starting and it started fine. This time i let it idle and warm up for about 20 minutes. Put in drive and it immediately stalled. Went to start again and this time completely dead again. Turned key and nothing happened and all lights. Worked. Called for a tow. Any ideas. We had a vehicle quite a Long time ago that the transmission went and everytime you put it in drive the engine would die. You could start it eveytime. This one you cant so it leads me to believe it is an electrical issue somewhere, but why did it idle fine in park. Thx for help
Old 01-24-16, 12:13 PM
the_tow_guy's Avatar
Having a hard time connecting the symptoms. Stalling when putting in gear could be locked up converter or other internal tranny failure. Why that would lead to it being electrically dead intermittently is a puzzle. Can you get a code reader on it to see if there's any codes?
Old 01-24-16, 12:14 PM
Temporarily Suspended
That points to a bad transmission converter. When you have the transmission rebuilt, always insist on a new converter. You may have two problems. The first is that it won't start. The second is the converter.
Old 01-24-16, 12:16 PM
That's the part that doesn't make sense.
I'm still thinking on it..... maybe a torque converter locking up ?
Old 01-24-16, 12:27 PM
The solenoid should still move no matter if the converter is bad.
Old 01-24-16, 12:40 PM
When it wont start it is acting like when the car is in gear and if you turn the keg nothing happens. Wondering if the neutral switch - if that is what it is called- could be an issue. If there was an issue with switch while moving the gearshift could it causd it to stall.
Old 01-24-16, 12:52 PM
The neutral safety switch can cause the vehicle not to start but I don't think it can cause the vehicle to stall.
Try starting in neutral then. The switch allows you to start in two positions.
Old 01-24-16, 01:00 PM
could just be all an electrical issue when you shift into gear there is some movement of the engine and wiring harness probably a bad connection causing both the engine to stall and likely causing the no start also.
Old 01-24-16, 01:50 PM
What's that rig have for a Ground Cable on the engine ?
Old 01-24-16, 01:52 PM
Good idea Allen. Typically if that was the issue.... the check engine light would be on with a code logged..... but not always.
