Replacing Jeep computer
I replaced the computer this morning on my stepson's jeep. The instructions that came with the computer stated DO NOT disconnect battery before installation! Well that is kind of hard to do since one of the screws holding the computer in place is directly behind the battery. I removed the battery just like I did when I installed the the used computer 2 months ago. I assume it will work just fine.
Any ideas as to why they would have that statement at the top of the installation instructions?
I've read where some vehicles require a 9 volt battery plugged into the cigarette lighter to maintain voltage. What year Jeep is it anyway?
I guess I would find out why they have that statement BEFORE I disconnected the battery ...
Why would you do exactly what they said NOT to do and assume it will work just fine ??
Good luck.
Good luck.
I have to ask the same question? I understand that you could not place the computer in it's location without removing battery, but did you have to actually make electrical connection with the battery disconnected?
It's 2002 jeep liberty. I replaced the computer [failing coils] 2 months ago with a junkyard computer. It ran great on the that computer but the oil light stayed on constantly [manually checked and found great oil pressure] When his income tax refund came he told me to go ahead and buy a rebuilt one with a warranty. If the old computer isn't returned [received by them] within 14 days of purchase they will charge my CC $100 and void the warranty. This was unknown until the package arrived yesterday.
I was supposed to install it tomorrow but but the highs are expected to be in the teens
and I was trying to beat today's snowfall [only half successful] and more snow is expected Sun - Tues
Both computers were installed in the exact same manner.
Temporarily Suspended
Received 0 Votes
When the battery is connected, power is always at the alternator & maybe some senors. It could be that when the new computer gets connected, it may have to read some of those sensors & the alternator. You could always reconnect the battery before you connect the computer.
I haven't heard back from him so I assume it's still working fine. At any rate my jeep barely made it up my driveway when I came home - I ain't about to go back out if I don't have to!!
Forget the battery for now.. Dont you have to progarm that computer? You have to vin check from what I know on the older cars to match the vin #'s to program it with a scan tool...
I had to supply the vin# when I ordered the computer so maybe they did it. With the junkyard computer all I did was hook it up and the jeep ran.
IDK... You went the cheap way out I assume? Just guessing that you said the comp was pre flashed...
Read post here...
I wish I read your other thread regarding this.. I have had experience with this before...
JEEP PCM / ECM...REPLACEMENT LESSON LEARNED - Forums - CNET
Read post here...
We didn't have the time/money to order a new computer back in december and the junkyard computer got him back on the road. The place I ordered the rebuilt computer from did have the lowest price and a lifetime warranty. All the other computers I found only had a 1 yr warranty. Didn't see any new computers for sale - all were rebuilt or used.
This was my first experience working with or replacing a computer.
Important Installation Information
critical steps
#1 do not disconnect the battery before installation
#2 make sure battery is fully charged and connections are corrosion free, replace battery if 3-4 yrs or older
#3 allow vehicle to run for 15 minutes on first startup
suggested steps
check all grounds and remove any corrosion/oxidation
check for electrical shorts or faulty sensors
critical steps
suggested steps
