How do I remove a paint scuff from car finish?
Old 02-27-16, 06:06 AM
P
Angry How do I remove a paint scuff from car finish?
Hello, My soulmate scraped the front fender of our Toyota against our garage's door trim. The door trim color is red while the car's paint color is white. I have already used a polishing compound to remove much of the scuff paint. I am hesitant to continue using the polishing compound. Any suggestions are appreciated.
Old 02-27-16, 06:42 AM
XSleeper's Avatar
Received 667 Votes on 617 Posts
Wet sanding with a super fine wet sandpaper will remove the abrasion from the clearcoat, but you are right, there is a limit to how much you can sand. We can't advise without being there and seeing/ feeling how deep the abrasion is. If it's through the clearcoat well then you won't be able to buff it all completely out. After wet sanding you would then use a product like 3M finesse it to restore the luster of the clear coat.
Old 02-27-16, 07:42 AM
ukrbyk's Avatar
Received 11 Votes on 8 Posts
Same procedure I described here.
http://www.doityourself.com/forum/pa...-question.html
Will work just fine.
