question about alternators
Old 03-14-16, 01:32 PM
P
So my alt needs to be replaced due to bad voltage regulator producing 20+ volts.
Ive shopped around and its $200 for one at the store here.
But my question is this. My alt is 130 amp and the re manufactured ones are 105-110 amp. Will this be an issue? because for $85 I can get a new one online thats 105 amp or a remanufactured one thats 110 amp.
Or I can get one used from a junk yard or something but I dont know how I feel about that.
Old 03-14-16, 01:37 PM
Received 321 Votes on 285 Posts
What does the book call for on your vehicle? was the 130 amp original or an upgrade? You might be able to just replace the voltage regulator.
Old 03-14-16, 01:51 PM
P
Temporarily Suspended
Try rockauto.com __________________
P
Well I may be wrong because it seems like they produced 4 different engines for this model car.
The book says nothing about the alternator.
Old 03-14-16, 01:54 PM
P
Rockauto almost $200 plus shipping.
Old 03-14-16, 01:58 PM
P
marksr the Voltage regulator is internal. Plus when I had the alt off the car I could here a bearing rattle so I may just replace it.
100 New Premium Quality Alternator Ford Taurus 2000 2001 3 0L 3 0 YF1U10300DA | eBay
Old 03-14-16, 02:50 PM
P
Something is wrong if rockauto wants that much. If there are 4 different engines, there might be more than one alternator. You have to clarify what engine you have & what it takes.
Old 03-14-16, 03:46 PM
Received 10 Votes on 7 Posts
Make/year/model/engine/pertinent accessories or we can't help you. We are not mind readers.
Old 03-14-16, 05:15 PM
P
2000 ford taurus 3.0 v6 OHV. You dont need this infor to answer this question honestly
Old 03-14-16, 05:27 PM
P
If he wants to search for the proper alternator, he needs that info.
Old 03-15-16, 02:59 AM
I understand that the voltage regulator is part of the alternator but it can still be replaced although it appears to be pretty pricey for your vehicle - Voltage Regulator ECH VR454 | NAPA Auto Parts although if there are other issues with the alternator it makes sense to replace the entire unit.
Old 03-15-16, 04:32 AM
A
Received 19 Votes on 18 Posts
you can probably save some by buying online if you can wait for it to ship in, you really don't want to be driving the car with it charging at 20 volts.
see similar prices on rock auto as the one you linked to on ebay but doesn't really matter where you buy it at, as long as it fits might want to check your 8th vin number if its an s you have the 3.0 dohc engine.
Old 03-15-16, 04:40 AM
the_tow_guy's Avatar
Received 55 Votes on 45 Posts
Checked locally for a a place that does starter/alternator repairs?
Old 03-16-16, 09:47 AM
L
Old 03-16-16, 01:00 PM
lawrosa's Avatar
Super Moderator
Received 60 Votes on 52 Posts
You must have been looking up the wrong alt... No you dont want to go down on amps.. If you have the 130amp alt in there then your engine code is S and not U 3.0L
The link below from autozone shows a 130 amp alt.. Thats what you should be getting..
$144 bucks is not too bad either...
Alternator Dlg7736-6-7 - Duralast Gold (DLG7736-6-7)
Old 03-16-16, 01:05 PM
lawrosa's Avatar
Super Moderator
But looking more into it I would get the 100% new alt for 174.00
Duralast Gold/Alternator DLG3408-16-2 - Read Reviews on Duralast Gold #DLG3408-16-2
