Is clutch fluid the manual transmission oil?
Old 05-09-16, 10:30 AM
B
2006 Toyota Camry 5 speed manual transmission. I had its brake fluid and transmission oil changed today. However, the shop manager wrote down brake fluid and clutch fluid changed on the invoiced charged for two jobs. He says for a manual transmission, clutch fluid is the transmission oil which I don't agree with. Is this an industry misnomer to call manual transmission oil as clutch fluid in the field in repair shops? Or did I get tricked?
Old 05-09-16, 11:46 AM
G
Received 2 Votes on 2 Posts
I think that you have a clutch slave cylinder. If that were flushed, it would use brake fluid.
I would go to the shop and have the manager get the mechanic to explain what was actually done.
I have found some of these "order writers" to be just order writers - not well versed on mechanics.
Old 05-09-16, 12:07 PM
pugsl's Avatar
Received 74 Votes on 67 Posts
Brake fluid goes in clutch master cylinder. Check owners manual it will tell you. If they put trans oil in there they owe you a new master and slave cylinder. Seals are ruined.
Old 05-09-16, 04:36 PM
chandler's Avatar
Received 6 Votes on 6 Posts
While it is certainly two separate jobs brake master and clutch master/slave), they should not have used transmission fluid in the clutch master/slave unit, and as Don says, they are toast at this point if they did.
Old 05-09-16, 04:55 PM
P
Temporarily Suspended
To me, changing brake fluid is being tricked. I've never done it & never will.
Manuel transmissions with over drive take automatic transmission fluid.
Old 05-09-16, 08:41 PM
ukrbyk's Avatar
Received 11 Votes on 8 Posts
OP, like others pointed out, BRAKE fluid is same as clutch fluid.
Manual transmission oil - they do not have fluids - is very high viscosity one and will simply not work in clutch application. Too thick.
Old 05-10-16, 02:44 AM
Received 321 Votes on 285 Posts
I agree! the odds are if they put the wrong fluid in the slave cylinder you'd have noticed before you got home. For piece of mind you should go back to the shop and verify ..... might even learn whoever did the paper work something
Old 05-10-16, 03:49 AM
pugsl's Avatar
Brake fluid absorbs moisture and can boil in high temperature locations. ( going down a mountain, heavy traffic). When it boils you lose braking.
Old 05-10-16, 04:23 AM
P
In 45 years, I've never heard or seen that happen.
Old 05-10-16, 04:55 AM
I once had a vehicle have an exhaust failure that packed the engine bay full of heat which boiled the brake fluid and affected the brakes .... so it can happen.
Old 05-10-16, 06:10 AM
P
so it can happen.
Maybe it can happen but telling customers that they should change brake fluid like they would change motor oil is an outright lie.
