Toyota 2003 3.0L radio with JBL replacing with Sony MEX-N5100BT
Old 06-17-16, 06:18 AM
My toyota has JBL so I am using the Metra 70-8113 for Sony MEX-N5100BT So far i have connected following
Red connects to Red on wiring harness of Sony
Yellow connects to Yellow
Blue connects to Blue
Blue/White connects to Blue/White
Black connects to Black
Black/White connects to Black/White
There is Solid Blue which is not on Sony MEX-N5100BT wiring harness Where should I connect that?
On Sony MEX-N5100BT wiring harness There are many besides above
green , green/black, purple, purple/black, white, gray white and
white/black which i am not sure where to connect. I am not sure am using correct wiring harness Metra 70-8113.
I can post pictures if needed.
Thanks for any help
S2K
Old 06-17-16, 04:34 PM
ukrbyk's Avatar
Jump to car audio forum. Guys there do nothing but car stereos. You basically need schematics to all the pig tails and Toyota wiring schematic for your year to match.
Old 06-17-16, 10:33 PM
Toyota 2003 3.0L
Is that a model ???
The JBL system has an amplifier in the car. The Metra 70-8113 is an amplifier connection plug.
It should come with four RCA plugs. Those four RCA plugs go to your new Sony. You wouldn't use the green , green/black, purple, purple/black, white, gray white and white/black which are speaker leads. Insulate them so they can't short to anything.
METRA color/function --------------------> SONY
Black Ground -----------------------------> black
Yellow Battery/Memory -----------------> yellow
Red Ignition/Accy -----------------------> red
Blue Power Antenna --------------------> not used if you don't have a power antenna
Blue/White Amplifier Turn On ---------> blue/white
Gray RCA --------------------------------> Right Front RCA
White RCA ------------------------------> Left Front RCA
Purple RCA ------------------------------> Right Rear RCA
Green RCA ------------------------------> Left Rear RCA
Old 06-18-16, 08:30 AM
@ ukrbyk's - Apologize. I could not find the forum for car audio.
Thanks Pete for direction. One last question
See picture where does the two blue connector go which was in the toyota's car audio to sony Name:  IMG_5432.jpg
Old 06-18-16, 08:50 PM
The one with the thicker wire goes to the antenna input jack on the back of the Sony.
The plug with the thin cable was the second antenna wire to the JBL radio which had dual diversity FM reception. That radio choose the antenna with the best signal. Your Sony does not do that.
Old 06-19-16, 06:45 AM
ukrbyk's Avatar
Old 06-30-16, 06:16 AM
Thank you very much PJMax and ukrbyk. I was able to successfully install and it works great. Again Thanks very much.
Old 06-30-16, 09:59 AM
You're welcome. Thanks for letting us know.
Old 06-30-16, 01:57 PM
Can someone link me to the car audio section of DIY forum? I can't find it either.
Old 06-30-16, 10:18 PM
The really isn't a car audio section. Start a new thread in this forum.
Old 07-01-16, 12:23 PM
ukrbyk's Avatar
See my post #6 here************************
