Wheel weight adhesive removal from rim
Old 07-22-16, 08:56 AM
I had a new set of tires mounted recently and of course the technician did not remove the adhesive left by the old weights. The design of my wheels is such that it is very noticeable and I want to remove it. I've used brake cleaner and a plastic scraper in the past. Is it safe to use this type of solvent on a wheel or should I buy a product specifically for adhesive removal?
Old 07-22-16, 09:00 AM
pugsl's Avatar
I would try goo gone or something similar. Brake cleaner should work apso.
Old 07-22-16, 09:01 AM
I've heard Goo Gone doesn't work very well, and brake cleaner evaporates too quickly. I'll likely end up using brake cleaner assuming it is safe for the finish.
Old 07-22-16, 09:07 AM
WD40 is a pretty decent remover as well.
Old 07-22-16, 09:12 AM
I agree. I've used WD40 to clean some aluminum motorcycle parts and it works very well. However, it leaves behind an oily residue. Maybe I'll remove the adhesive with WD40 then follow it up with brake cleaner.
Old 07-22-16, 10:15 AM
I use ether starting fluid as a universal adhesive solvent. You must remember that it is EXTREMELY FLAMMABLE and the vapors can literally knock you out. It may also remove some paints although I have not experienced that problem.
Old 07-22-16, 11:03 AM
the_tow_guy's Avatar
I too usually grab the WD-40 first to see if it'll work.
Old 07-22-16, 03:47 PM
The WD-40 may soften and dissolve the glue.
Another choices is lacquer thinner. If the weights were glued onto an aluminum rim..... the residue will need to be power buffed off. No amount of any cleaner will remove it completely as the aluminum is too porous.
Old 07-22-16, 07:22 PM
ukrbyk's Avatar
Steam and rubbing alcohol to wipe softened adhesive of..
