'02 Grand Marquis - Steering alternates extremely firm to normal when turning.
Old 08-21-16, 08:34 PM
T
Received 2 Votes on 2 Posts
Mom thought it was power steering going out on her car, but when i drove it i had never felt anything like this. It's like if the steering wheel is a clock face, every 15 minute chunk alternates between feeling like the power steering is out, to normal and smooth. So if i make a sharp turn, it goes 'hard, smooth, hard' and back, depending on how much i turn it.
Ideas?
Old 08-22-16, 03:29 AM
Received 268 Votes on 237 Posts
I'd open the hood and inspect the steering column all the way to the steering gear box [or does it have rack and pinion?] and look for obstructions or worn/broken parts.
Old 08-22-16, 11:21 AM
ukrbyk's Avatar
Received 10 Votes on 7 Posts
Rack n pinion bad or very low fluid in PS system but by then it'd be doing helluva noise.
Mybe PS pump is acting up. But I lean towards RNP
Old 08-23-16, 07:11 PM
iceman681's Avatar
Received 3 Votes on 3 Posts
bad u-joints in the steering shaft. they tend to go bad right at the steering gear. will have to remove to know for sure.
Old 08-24-16, 04:28 PM
T
Thanks everyone.
Ok, well i went out and could only see 1 u-joint connection visible. I sprayed some PB blaster on it, and also put a bunch of high temp grease on it. Drove it around after, and it immediately fixed the problem. Feels pretty normal now... if it isn't 100%, it has to be very close.
I can feel just the slightest little bit of drag occasionally when i turn it all the way, but for all i know that is the normal feel for a properly functioning u-joint... it could have been like that all along, and now i just notice it more because i am anticipating the huge drag that was occurring in those same spots.
Here is a pic of the steering shaft... there was a rubber boot enclosing the area where i have the long red line drawn. Dont know what that is, and it enters into an enclosure (steering box? i dont know anything about steering) at that point. The short red line is the u-joint i greased, and just beyond that it enters into the firewall.
http://i.imgur.com/rtZBwDA.jpg?1
Here is a close up of the u-joint i greased:
http://i.imgur.com/MwGM9JL.jpg
So i guess for now i am going to let it roll like this, unless i am in imminent danger of it failing even though it's greased, or something. Thanks for all the feedback, and let me know if you have anything to add!
Old 08-24-16, 08:43 PM
iceman681's Avatar
was not sure when they changed the style of steering shaft. the older had two u-joints. one at the top where u lubed it and the other one at the bottom where they upgraded it with the rubber joint( the one that used to go bad all the time). glad to have helped.
