Clicking Sound Upon Shutting Off Engine
Old 08-23-16, 07:30 AM
Received 22 Votes on 17 Posts
About four or five seconds after shutting my engine off, I hear several clicks from under the hood. It seems to be coming from the top of the motor and is a relay clicking sound. What is this sound? Injectors? Vehicle is a 2011 Acura TL. BTW, no, it is not heat shields, etc. cooling off. It is five or six rapid clicks and then stops.
Old 08-23-16, 08:07 AM
P
Received 1,560 Votes on 1,403 Posts
All of my modern cars have made odd noises when turning the car off and even when opening the door. Most notable is my BMW X3 which makes a lot of odd noises when you open the door after it's been parked a while. You can easily hear relays/solenoids clicking and motors running...
Old 08-23-16, 11:38 AM
ukrbyk's Avatar
Received 43 Votes on 35 Posts
It's your heat shield cooling down. Heat shield covering exhaust manifold. Or the manifold itself. As it sits rather high up on the engine, and metal is great sound conductor, it surely will sound like top of the engine.
Old 08-23-16, 12:55 PM
Sorry, but it's not the heat shield. The engine can be stone cold and it does it. It's a distinct relay clicking sound and it happens consistently. It's five or six rapid clicks and that's it.
Old 08-23-16, 01:08 PM
XSleeper's Avatar
Received 1,525 Votes on 1,369 Posts
Probably relieving fuel pressure.
Old 08-23-16, 08:48 PM
ukrbyk's Avatar
Why be sorry? It was as good a guess as anything else. Second guess is ABS pump actuator resetting itself. My 07 Camry has "by wire" brakes and every time I shut her down, there is loud staccato of resetting brakes actuator valves from under the hood.
Old 09-18-16, 04:21 PM
Here's a video of the sounds. Seems like it's coming from inside the intake manifold.
View My Video
Old 09-18-16, 05:15 PM
chandler's Avatar
Received 9 Votes on 8 Posts
Link is no good. My Jeep Grand Cherokee Limited made sounds after shutting down the engine. It was mostly the air baffles in the heat/cooling system resetting themselves to a default position.
Old 09-18-16, 05:21 PM
XSleeper's Avatar
If its coming from the intake you are probably hearing normal IMRC operation.
https://www.yourmechanic.com/article...runner-control
Old 09-18-16, 05:54 PM
ray2047's Avatar
Received 15 Votes on 13 Posts
To view Mossman's video type the link below in your browser.
Mossman, Tiny Pics is blocked.
Old 09-19-16, 10:41 AM
This will make it easier for copying and pasting purposes:
http://************/r/2a7brr4/9
Replace ***** with tiny pic .com
