Checking speedometer accuracy.
Old 08-24-16, 08:04 PM
Norm201's Avatar
Received 256 Votes on 230 Posts
Is using a GPS and/or cell phone app good enough to check the accuracy on a speedometer? I always thought my van was about 3 to 5 mph reading over the actual speed. And seemed to check with an old GPS I used. However, I now started using a smart phone app and it reads almost dead on (although there is a time delay of a 1/2 second or so).
On my car I have a HUD display attached to the OBD2 connection and it corresponds exactly to the speedo needle on the dash. It also checks out with the smart phone app (DigiHUd Speedometer).
Old 08-25-16, 04:24 AM
chandler's Avatar
Received 6 Votes on 6 Posts
I find my GPS to be pretty accurate. I have never used Maps to gauge speed, but I guess with any satellite oriented receiver, there is a lag time. I know this from watching altitude markings. Here in the mountains it will read ascending altitude even after I top a gap and begin downhill.
Old 08-25-16, 05:08 AM
Received 331 Votes on 294 Posts
Before GPS I always checked the odometer with the mile markers on the highway. Might not be as accurate and requires some math but always gave me a good idea of how far off the speedo was after a gear or tire size change.
Old 08-25-16, 05:40 AM
the_tow_guy's Avatar
Received 60 Votes on 49 Posts
Wife's Camry indicates about 1-2 mph below what the gps does when we have it on. Also most times when we go by a portable radar speed sign, they also show the same error, so I'm assuming the car is actually off. Kind of surprising really.
:WRECKER:
Old 08-25-16, 05:56 AM
pugsl's Avatar
Received 74 Votes on 67 Posts
I get about a 2 mp difference between GPS and speedo.
Old 08-25-16, 06:28 AM
XSleeper's Avatar
Received 721 Votes on 667 Posts
Mine is +/- 2 mph. If my cruise is set on 70, gps speed varies from 68 to 72.
Old 08-25-16, 06:40 AM
Received 10 Votes on 7 Posts
There are many different tires out there to fit your vehicle from numerous manufacturers in various quality levels and design (all-season, performance. M/S etc)
You would have to check the circumference of all those tires and verify that they are all identical to expect a speedometer to be accurate in all cases.
And don't forget tire pressure - a couple of pounds either way will affect speedometer readings.
So many variables you can't expect speedometer readings to be "right on"
