Small leak after Subaru Forester 2012 engine replacement
Old 09-27-16, 06:42 AM
B
Subaru Forester 2012 engine seized at 110,000 miles. Not sure why, but it was not due to lack of oil or not doing proper oil changes.
Engine was replaced by Subaru dealer last Friday. Have observed in driveway small amount reddish brown fluid (teaspoon or less) on front passenger side about one foot in from tire.
Can I assume this is likely a transmission fluid leak related to the engine replacement? Thanks for all responses.
Old 09-27-16, 12:51 PM
chandler's Avatar
Received 9 Votes on 8 Posts
No matter, it should be resolved by Subaru since they did the engine replacement and had to crack the cases to do it.
Old 09-27-16, 01:09 PM
B
Thanks chandler. Would you mind explaining what you mean by "crack the case".
Thanks.
Old 09-27-16, 01:41 PM
pugsl's Avatar
Received 76 Votes on 69 Posts
They had to open parts or move them.
Old 10-07-16, 03:42 PM
W
When an engine is replaced,they have to remove it from the tranny. Usually that seal in between the two in older cars tends to leak. They might have not put something back correcty,wither gaskets, or overall the two parts. Does the car shake in Drive? Try to diagnose the leak yourself and see where its coming from. Either way,subaru has to remedy the problem.
