2010 Hyundai Sonata horn
Old 10-08-16, 09:26 AM
Hello all,
My 2010 Hyundai Sonata's horn just failed me. I believe that they come with a double horn - one high frequency and one mid range. The mid range horn was the one that went out and now the car sounds like it is auditioning for a Bugs Bunny role. A couple of Youtube vids and other research tells me that I may have to pull off the bumper and grill to get to the bad horn under the left headlight.
I was considering moving over to a more pleasant sounding horn - like maybe something from a Honda or a Toyota.
Does anyone know if there will be a voltage compatiblity problem and/or a voltage relay problem? I'm not too worried about the physical hookup at this point.
Thanks
Old 10-08-16, 10:07 AM
The horns are behind the grill.
The voltage will be the same. If you replace like for like you'll be fine. If you intend to install a larger horn system you may need to increase the amount of switching current.
The hookup is usually just one wire.
