2009 dodge nitro heating problem
I have heat on one side of my vehicle only, but windows don't frost up, heater core has been flushed,thermostat changed. Any suggestions? Thanks
Welcome to the forums! Sounds as if you are experiencing a blend door problem that is prevalent with Dodge/Jeep. There is a way to R&R the blend doors without the standard "take everything from your windshield to your seat" out of the vehicle. I googled "heat blend door replacement" and the name of the vehicle. You may have good results doing that. The videos are quite helpful.
