2008 Pontiac grand prix rear wheel noise.
Old 11-27-16, 08:56 PM
So, a few weeks back I hit a fence that damaged my rear wheel, blowing out the tire. I got a new one. I now hear a nose coming from the tire. It's a "wub wub wub" sound that gets faster the faster I drive. I thought maybe it's an unbalanced tire, so I rotated it the tire with the front driver tire to see if the noise followed the tire but it didn't. I'm thinking maybe a wheel bearing? Any other thoughts? How can I test the wheel bearing?
Old 11-28-16, 03:41 AM
Welcome to the forums James!
The first thing to do is jack it up and spin the offending wheel. Look and listen for any discrepancies. Usually it isn't a big deal to replace the entire hub.
Old 11-28-16, 04:08 AM
pugsl's Avatar
While it is jacked up look for any bent parts. If you damaged wheel it doesn't take any more to bend something else.
Old 11-28-16, 11:20 AM
Also, make sure the wheel nuts are good and tight. If the nuts loosened it can cause a noise
Old 11-28-16, 02:24 PM
ukrbyk's Avatar
It wobbles. Hence that noise. Hub bearing will make crunching noise. Something's bent, most likely control arms. They change geometry of the entire knuckle then.
