ford 500 2005
Old 03-31-17, 08:22 PM
ford 500 2005
When I'm driving down the road my warning signal under the dash will go off for a second or so.Also when I go over bumps in the road.also had problems a few weeks ago with the doors not unlocking with the key button.
Old 04-01-17, 02:27 AM
pugsl's Avatar
Need more info. What warning light engine something else?
Old 04-01-17, 08:17 AM
Ford 500 2005
No light comes on its like the door open signal
Old 04-01-17, 08:37 AM
chandler's Avatar
It could be the adjustment of the door switch, which may or may not be elementary. On my 2001 Dodge Ram, it is easy. You'll just have to look at the switch to determine if it is at fault or its adjustment. If it is your door switch, you should also get a "door ajar" light, albeit as short a span as the signal, it may not be readily visible.
Old 04-05-17, 08:54 AM
CasualJoe's Avatar
Has the battery ever been changed in the key fob? I just changed mine yesterday at 11 years old (yours is 12 years old), it was just starting to not respond every time I pressed it.
Trackbacks are On
Pingbacks are On
Refbacks are On
