2010honda
Old 07-10-17, 11:04 AM
2010honda
Air quit working where do I start!
Old 07-10-17, 11:07 AM
Received 169 Votes on 150 Posts
As in no blower? no cold air or what? have you checked the fuses?
Old 07-10-17, 08:57 PM
ukrbyk's Avatar
Received 5 Votes on 5 Posts
first question - does the ac compressor kick in? If not, you are out of refregerant and it needs to be checked for leaks, fixed and recharged.
Old 07-11-17, 10:25 AM
Try replacing the engine air filter, then the engine will get more air.
Old 07-25-17, 09:43 AM
a) when starting the engine from cold, the engine fan shouldn't come on.
turn on the ac fan and you should see one of the two (the ac fan) come on.
b) recharge the system. If it now blows cold but blows hot again after a while of driving, recheck the pressure. If the pressure is lower than when you recharged it, find the leak via UV light and repair the leak.
c) As stated, check the fuses, replace the AC compresser and AC fan relays. you can switch them, they're the same, and see if that makes a difference then you know one is bad.
Unfortunately the compresser (and clutch and coil) going bad is a common problem for Hondas and a PITD to replace.
My old lady has an '11 CR-V and it all went out <=80k miles, ridiculous.
Had to replace the dryer as well.
That job on my VW is a 1/2 days worth of work, so far it's been 3 weekends.
Getting to anything sucks, I told her to sell it or take it to the shop 'cuz I ain't wrenching it anymore.
