I need help cleaning windshield inside car.
Old 07-14-17, 01:24 PM
Received 1 Upvote on 1 Post
I have a 2001 Pontiac Grand Am. The rear view mirror came off several times over the years and I always used Krazy Glue to put it back on. Big mistake on my part. I just found out that they have adhesive kits for this kind of thing. Anyways, there's a lot of residue on the windshield from the glue and this stuff simply will not come off. I have tried Windex, razors, stainless steel scrubbers, and other products for removing grit and grime and NOTHING can get this stuff off--not even a little bit. I need something that's heavy duty + commercial grade but even that probably won't be able to get it off. Any ideas?
Old 07-14-17, 01:33 PM
R
Received 67 Upvotes on 52 Posts
Acetone..................................................
Old 07-14-17, 01:41 PM
Received 3,742 Upvotes on 3,357 Posts
A sharp razor should be able to remove the glue.
Combined with a little acetone may make it easier.
Received 1,248 Upvotes on 1,192 Posts
Yep, acetone is the proper solvent for cyanoacrylate.
Old 07-14-17, 01:42 PM
So, I put some on a microfiber cloth and wipe it down? Does it drip at all?
Old 07-14-17, 01:43 PM
I wouldn't use microfiber, the acetone could damage the towel. I'd use something like a cotton or paper towel.
Old 07-14-17, 01:47 PM
Received 800 Upvotes on 703 Posts
.... and remember acetone is one of the hotter solvents and doesn't play nice with anyone with sensitive skin. I'd use a rag or folded up paper towel, wipe it down, use a razor blade to remove the big stuff and then finish off by scrubbing the area with acetone.
Old 07-14-17, 02:06 PM
That's what I figured. Thanks for the suggestion guys!
Old 07-14-17, 10:28 PM
ukrbyk's Avatar
Received 57 Upvotes on 48 Posts
Officially acetone, like others said. BUT! Make sure to cover dash with plastic as acetone is also plastic solvent. You don't want to have drops down on it.
You want to soak it, so getting a fine sponge or small rag soaked in it and holding it against glue for few minutes is necessary. But that comes with vapors and acetone gets people high. Just saying.
BTW, that kit that you fame so much has exactly that - super glue. And Gorilla is super glue. Reason it falls down is you have not clean and greasy surfaces you are trying to bond. So gloves and denaturated alchol as degreaser is required.
Oh, and use of promoter makes very strong bond. ZipKicker is one of them.
https://www.amazon.com/Pacer-Adhesiv.../dp/B0073WU0N0
Old 07-15-17, 10:35 AM
B
When all else fails, read the instructions!
That is product packaging will say which solvent to use for clean-up. Different for various glues.
Old 07-15-17, 03:18 PM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
Who said anything about Gorilla Glue? And it's not what's commonly known as super glue anyway. Super/Krazy/Insta glue is cyanoacrylate. The commonly referred to original Gorilla glue is a polyurethane. Of course they make a cyanoacrylate glue...doesn't everybody?
Old 07-16-17, 07:58 AM
ukrbyk's Avatar
Right, he used Krazy Glue. It's just that Gorilla is so much advertising that by the time I read through all posts and started typing it capsized in my head as Gorilla.
You showed me. get a donut.
Old 07-23-17, 07:59 PM
F
Alternative
Nitromethane based debonders are available at hobby stores, and are easier to work with verses acetone, but acetone (or nail polish remover) will work.
More info here...US-1 Super Solvent 2oz debonder for CA glue, will remove super glue from Satellite City Instant Glues
Old 07-23-17, 08:23 PM
Interesting. A first for me hearing of it. Thanks for the info
