This can't be good for my tire??
Old 09-06-17, 03:31 PM
I know this isnt good but is a gash like this considered dangerous and should be replaced with a new tire ASAP?
Its on a 2015 Toyota Highlander
Old 09-06-17, 03:34 PM
Received 167 Votes on 148 Posts
I'd replace it! ........ flirtying with a blow out
Received 62 Votes on 58 Posts
Dangerous in that there's an increased likelihood of an explosive blowout of the tire now.
Your call but I would probably at least take it to the shop and have them take a look (keep in my the shop I go to is run by a friend I trust as opposed to some stranger who just wants to sell me tires).
Old 09-06-17, 03:37 PM
Received 1 Vote on 1 Post
Now that you've publicized your knowledge of it, your Insurance Carrier will be expecting you to perform your due diligence,
How deep a cut is it . . . . and do you know what caused it ?
People around here usually use an Ice Pick on my tires.
Old 09-06-17, 03:49 PM
ok thanks. good point about the insurance carrier. no clue how it happened. its not very deep, maybe 1/4". And I'm sure when I try to see if my tire warranty covers it there will be some sort of clause saying they dont cover this sort of thing. ok thanks for your help!
Old 09-06-17, 03:54 PM
Tires with sidewall cuts must be replaced.
Old 09-06-17, 04:15 PM
There may be a "Road Hazard" provision on the Tire Warranty.
Old 09-07-17, 03:40 AM
I'm thinking like Vermont, if there is a road hazard warranty - it should be covered. If you don't have road hazard it won't be. Normally you pay extra for the road hazard coverage.
Old 09-07-17, 05:00 AM
Originally Posted by bheron
". . . This can't be good for my tire?? . . ."
Can it be good . . . . no, it's not an improvement !
In my business, I look at every aspect or change to a house or a neighborhood and ask:
Is this truly GOOD, obviously BAD or simply NEUTRAL ?
Everything in life boils down to being in one of those three categories.
After exhaustive analysis, and anyway you cut it, I think this change to the tire is one that is BAD !
Old 09-11-17, 09:13 AM
Tire Cut
Just dealt with this myself, I have a divit cut out of the sidewall. The conventional wisdom is replace, and that is what I did. That said, if there is no cord showing, ie. a surface cut, and you are just doing low speed driving around the city, it is not like you need to do it immediately. Some would put it on a rear axle, and take their chances so at least a blowout would not be as bad as on the front affecting steering. But for the price of a tire, and the importance of tires for safety, I didn't overthink it.
