Stuck CD
Old 09-24-17, 06:18 PM
Stuck CD
I have a 99 Mazda Protege and a cd is stuck in the player. It will neither play nor eject. What can I try to get it to eject?
Old 09-24-17, 08:00 PM
Is that a single disc indash unit or a multi disc indash unit ?
There really isn't much you can do from outside the unit. You could pull the unit out of the dash and possibly get the CD(s) out but the unit won't likely play CD's again.
I used to repair automotive CD players..... they are not DIY repair items.
There are factory authorized repair centers that can repair the unit but if I remember correctly.... the price is around $125.
Old 09-25-17, 02:11 AM
Look for a pin hole in the tray & stick a pin in it.
Old 09-25-17, 09:22 AM
"I used to repair automotive CD players..... they are not DIY repair items."
Best advice.
I'm a retired electronics tech and you can do a lot of unnecessary damage trying to get the disk out .... when taking the unit to a technician is the best answer
Old 09-26-17, 10:48 AM
If I find the pin hole, should the unit be on when I try to push something into the hole?
Old 09-26-17, 11:40 AM
pugsl's Avatar
Usually will just pop out without power but try both ways.
Old 09-26-17, 11:47 AM
The pinhole is access to a mechanical catch, shouldn't matter whether the power is on to the unit.
Old 09-26-17, 06:22 PM
That's correct, no power is needed.
Old 09-27-17, 05:48 AM
This unit is a single disk player. There is an eject button on the right and a power button on the left. There is just a slot to push in a cd. I have searched and searched for a pin hole and cannot find one. Any suggestions on where to look?
Old 09-27-17, 06:35 AM
It has to be where you push in the tray.
Old 09-27-17, 06:39 AM
pugsl's Avatar
If just a slot I don't think there is a eject pin hole.
Old 09-27-17, 10:49 AM
There is NO pin on a single disc player. If there was a pin release on an indash changer.... it will only release the cartridge if the CD's are all in it. Usually a CD gets stuck outside the tray and it won't release.
Here's one thing you can try. Disconnect the negative battery lead. Tap the brakes a few times to discharge the ECU. Wait five minutes. Reconnect battery. Now try ejecting CD.
Old 09-27-17, 12:07 PM
biketrax's Avatar
IF you can see it ? and its partially out.....
Sometimes if you can see a little bit of the CD, then it may be stuck in limbo. I would take something to the effect of a thin wooden(or plastic) letter opener the ones that resemble sheaves or small swords, a little nudge in or out (or perhaps up or down) so the mechanism could push it out and this could save the day. This has worked for me on several occasions.
Good luck
Just a proven method that's worked for me!
Providing its not SUPER JAMMED!
