1999 chevy air conditioner problem
Old 09-25-17, 01:12 PM
N
unit cools, covered with condensate, but blows hot air...all the settings for air conditioner to blow cold air are set correctly. what else do i need to check
Old 09-25-17, 01:19 PM
Received 840 Upvotes on 737 Posts
Is the blend door operating correctly?
Old 09-25-17, 01:31 PM
N
welll.......thats why i came to this site. sorry to admit this, but i do not know what the 'blend door'
is, or how to find it. Is it under the hood, or is it located inside the cab underneat the control panel?
Old 09-25-17, 01:42 PM
N
Thanks for the reply...
i did find a video on the blend door actuator. how do i check to see if it is working properly or not. it look like it comes out easily. Do i just buy a new one and try it out....or is there some way to know if that is the problem, or is not the problem?
Old 09-25-17, 01:55 PM
I've never worked on the electronic ones, the old type had a linkage that opened/closed the door. It's normally located under the dash on the middle to passenger side. If the door opens/closes it's operating properly. If it doesn't move you are probably stuck on heat.
Old 09-25-17, 02:13 PM
N
1999 chevy silverado air conditioner problem
thanks for the tip. the chevy blend door actuator.It does exattly what you said...i causes a door to open or close and i can purchase one for about 40 bucks at autozone. I do need to get on my back and look up in there to see if I can maybe do this myself. Hopefully I will be able to determine if that is indeed the problem. If it is this will be a fairly cheap fix. Thanks for getting me going in the right direction. First i am going to see if i can get access to the unit and am able to see if the door is operating or not operating. If that is the problem I will get a new part and change the old one out....THANKS AGAIN FOR THE TIP. I TILL KEEP IN TOUCH............
Old 09-25-17, 04:22 PM
Received 3,986 Upvotes on 3,578 Posts
Based on the truck package it could be mechanical or electronic. The door is pretty much behind the radio. Here's a good video if you have the mechanical style. A little newer truck than yours but the idea is still the same.
you tube/watch?v=syTv59MD8ns
