Battery light coming on only during turns
Old 09-28-17, 09:47 AM
Hi all,
I have a 2003 cadillac deville with a strange issue. Runs and starts fine but yesterday the battery light started coming on only as I am turning corners with the vehicle then it goes off. I can drive for miles straight and stop at signals without turning and it doesn't come on. Any thoughts. Thx
Old 09-28-17, 11:54 AM
Received 132 Votes on 118 Posts
Check the battery cables and fan belt to make sure they are snug. If it's not something simple like that I'd be looking for a short in the wiring somewhere.
Old 09-29-17, 01:55 AM
Gunguy45's Avatar
Super Moderator
Received 2 Votes on 2 Posts
Actually had a break in a wire that only showed up sometimes. If I accelerated and the engine torqued over, the break would appear and I'd get a battery light. Turns, slow speed, slow steady acceleration, no problems. Took forever to find it. Very hard to simulate except for pulling on and shaking the wiring harness.
Old 09-30-17, 05:05 PM
ukrbyk's Avatar
Received 5 Votes on 5 Posts
Alternator belt. or, serpentine. When you turn, you put strain onto engine, as power is taken away somewhat by power steering. then alternator undeperforms. Or, alternator is headed south.
Also, entire power train moves when you turns. So it may cause a loose connection show itself.
Old 10-02-17, 09:21 PM
Aside from a loose connection, I'll put in another vote to check the belt and tension/tensioner.
