Measuring tire pressure always leaks air?
Old 11-11-17, 12:03 PM
I have some digital tire pressure gauge that is highly rated. They worked fine when new, but after 2 years, air tends to leak when I push the gauge onto the valve stem until I align the gauge at the exact angle and push hard on it.
This means I have to inflate the tire no matter what, which is annoying.
Is there a solution for this problem?
Old 11-11-17, 12:12 PM
Received 508 Votes on 478 Posts
The gauge may be highly rated because it's accurate.... not for its durability. The rubber seals tend to dry out on many of those gauges. A little silicone or 3in1 oil on the rubber seal would help.
Old 11-11-17, 12:13 PM
Received 16 Votes on 15 Posts
I think the solution is to get a new tire gauge. There are plenty available for under $20.
Old 11-14-17, 02:43 PM
Tape
There is probably no rubber seal in the chuck, or one that failed or fell out. Get some 3M rubber self sealing tape, use a hold punch and make a little gasket to slip into the chuck. The cheaper gauges all have your problem, even some of the expensive ones have seals that don't last very long.
