Subaru 2015 Forester
Old 01-30-18, 11:18 PM
Tail light brake light bulb burned out. Removed two bolts holding lens but CAN NOT remove the plastic lens. Neighbor Subie owner says tail light lens notoriously DIFFICULT to remove!
Know a trick? Hard to grip. Using rubber kitchen gloves but can't budge it!
ANY suggestions welcomed!
Old 01-31-18, 05:16 AM
the_tow_guy's Avatar
Received 32 Votes on 25 Posts
Not familiar with the configuration on that lens. If the mount bolts are external, i.e. the open holes face the rear of the vehicle as opposed to them holding from inside, then you might take a slightly larger wood or sheet metal screw and very carefully (emphasis on very carefully) screw them slightly into the plastic hole. Just enough to get a little grip and then try gently tugging on them. Have to be very cautious of screwing them too far in and splitting the plastic.
Old 01-31-18, 05:30 AM
Received 1 Vote on 1 Post
Old 01-31-18, 08:15 AM
YouTube is your friend. I was envisioning an individual lens vice the entire assembly.
Old 01-31-18, 10:17 AM
You're in my will! Thanks so very much for the link! The video answered all my questions! THANK YOU!
Joe Bronx
