PU tires
Old 05-13-18, 03:23 PM
PU tires
2001 silverado 4x4
These take 245/75/16 normally
can I run 235/70/16 on the 6 lug wheels?I am looking for a good
all around tire under 95$ if possible..any ideas??
Old 05-13-18, 03:37 PM
Gunguy45's Avatar
Super Moderator
Received 2 Votes on 2 Posts
Actually...to keep your speedo accurate...you'd need to go bigger..to about a 265/70. That's only a .3% diameter difference and about .8" wider. The 235's would be skinnier and a lot shorter. Will also depend on your wheel width.
https://tiresize.com/calculator/ Good place to do the comparisons.
As to brands...you'll have to decide size first then just shop around. I found some for my truck made by Michelin (IIRC) with a different name on the side that were only $47 at Walmart. Don't intend to do a lot of driving, no snow and no offroad...so they work for me.
