2013 Honda Civic Ignition Wiring Colors
Old 05-28-18, 07:18 AM
Hey guys! I'm trying to bypass/trick the transponder ognition disabler on my 2013 civic but I can't seem to find the ignition harness colors for that year and the older ones don't match up the colors are all wrong. Tell me what happen to have access to the diagram?
Old 05-28-18, 08:25 AM
For referwnce, this is what I'm looking at. Are these even the correct wires?
Old 05-28-18, 11:27 AM
Received 408 Votes on 384 Posts
Welcome to the forums.
You cannot bypass/trick the transponder system. The transponder MUST see a proper code before it will allow the car to start.
You can use an immobilizer kit like this basic one .....
Directed-Electronics-555I-Bypass-Module
I use this one as it has more functions and I can program it myself from my laptop.
Directed-Electronics-PKH34-Transponder-Interface
The kits require you to have two working keys for the car and then they assume the task of being another key.
The actual ignition colors should be.........
White is 12V+ input.
Black/white is starter.
Black/yellow is ignition 1 (hot in run and start).
White/black is igntion 2 (hot in run).
Yellow is accessory.
Look up the 555I kit. Look at the instructions. It will tell you the immobilizer colors.
Immobilizer data: orange/black (pin 2 in 7 pin immobilizer plug)
Key sense: green (in 7 pin immobilizer plug)
Security/power: pin 5 in 7 pin plug.
