1996 dodge caravan has alot of issues
Old 06-03-18, 04:31 PM
So i have a '96 caravan. Lately its been dropping RPMS when ever the brakes are applied and shuts off. Any one have any idea on why its doing all of these all of a sudden? Im at a loss here.
Old 06-03-18, 04:42 PM
XSleeper's Avatar
Received 299 Votes on 272 Posts
Do the brakes seem to be working normally when you step on the brake? Or is the brake hard to push? If so, it could be a vacuum leak in the brake booster.
Old 06-03-18, 06:40 PM
Brakes work fine. No issues with pressure or alot of play in them.
Old 06-03-18, 07:54 PM
Received 9 Votes on 8 Posts
sounds like an idle issue may try cleaning around the throttle plate to see if it helps if you have a check engine light on would probably check codes
Old 06-03-18, 09:01 PM
Thanks for that possibility. That will be my first thing to check tomorrow morning. I will update tomorrow.
Old 06-04-18, 06:33 AM
Received 5 Votes on 4 Posts
Is the torque convertor staying locked up?
Old 06-07-18, 07:21 PM
A couple of ideas,
Could be your idle is too high, when braking the computer tells the engine the rpms are too high and retards the ignition. So check if your engine rpm at idle where it is supposed to be.
Or, could be an ignition timing problem, my guess would be the crank or cam position sensor needing replacement.
