Acura fuel problem
Old 06-17-18, 12:43 PM
Acura fuel problem
Hey i am struggling here...any help will be appreciated...99 cl 3.0 v6...kid repeatedly ran the car completley out of gas. Now i have changed filter and injectors annd still the car falls flat on its face once gas pedal is pressed...help
Old 06-17-18, 07:09 PM
have you hooked up a pressure gauge to see if its losing fuel pressure when you press on the gas
Old 06-17-18, 07:17 PM
I'd get the kid to fix it .....
Old 06-18-18, 07:09 AM
The fuel pump is lubricated and cooled by the gas that it's in. It's possible that the pump has suffered damage from being run dry repeatedly. Also, there is usually a small filter/strainer on the pump itself. Did you check that? Frankly, if some sediment managed to get past the pump filter, there could be a partial blockage many places in the system.
Alan is right, checking the fuel pressure is the best place to start.
Old 06-20-18, 06:17 PM
brian44220's Avatar
Maybe hood a code reader up and see if any faults are stored. But yes I would check fuel pressure to, spending money and replacing good parts is no good.
Old 06-20-18, 09:22 PM
iceman681's Avatar
i would check MAF for dirt and make sure the air boot is on right.
