2010 VW Beetle window problem
Old 08-11-18, 11:12 AM
P
Question 2010 VW Beetle window problem
driverside power window will row down when you try to roll up will come up little way then down by it's self then you roll back up little bit goes back down then almost up you have to play with switch to get up HELP
Old 08-11-18, 11:27 AM
A
Received 34 Votes on 32 Posts
probably has a regulator or window motor problem.
Old 08-11-18, 03:44 PM
brian44220's Avatar
Itís called pinch protection, you probably have a problem with the window guid binibg causing pinch protection to activate a go back down, either that or the cables on the regulator are coming apart but most likely something to do with the track, try to spray lithium spray down the track area, if it persists take it to a mechanic.
Old 08-11-18, 04:46 PM
Received 1,616 Votes on 1,488 Posts
It could be a track problem but I wouldn't recommend spraying lithium grease on the track.
Some dry silicone lube would be a better choice.
Old 08-11-18, 05:18 PM
brian44220's Avatar
Pjmax
Donít know what I was thinking, silicone spray is best sorry for wrong recommendation.
Old 08-11-18, 06:06 PM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
Actually...if you have access to the tracks (door panel off) white lithium IS the stuff. But not just sprayed willy-nilly down into the door.
Old 08-15-18, 12:09 PM
F
You can put pull the switch for the window to go up, and once its up, then pull up the switch again and hold for two seconds. That resets the pinch control. Or, you can disconnect the battery for about 15 minutes. This should also reset the pinch control mechanism. Might solve for things. If it recurs, then as noted the regulator which I think includes the pinch control is failing or the tracks are binding.
