Jeep Patriot (ABS)/ ESP BAS/4WD! traction control lights on
Jeep Patriot (ABS) and ESP BAS and 4WD! and traction control lights were on.
After changing the bearing of the front tire, the mechanic gave it that way.
What I can do?
What I can do?
Since you have computer trouble codes logged..... the best thing to do is to have the computer code scanned to see what codes are stored. I would think your mechanic should have been able to do that.
Around here the biggies.... Pep Boys, Advanced Auto, Auto Zone, etc. will scan the system for free. Not sure if you have any place like that avaialble to you down there.
So there are several reasons why an ABS light will come on, one being a bad ABS sensor in the bearing, how/why was the bearing diagnosed as the cause?
Mechanic RETURNED vehicle to you with all those codes on? Seriously?
Was it the same way BEFORE he worked on it?
I'm with Marq - it is very easy to damage or dislodge or somehow else mess up ABS sensor or its connection, replacing hub bearing.
