07ChevyMalibu Lost keys&got new key cut LilCar With Lock symbol Wont Start
Old 11-25-18, 09:31 AM
B
2007 Chevy Malibu Ls Lost keys&got new key cut Lil Car With Lock symbol Wont Start
when lost key i had unhooked everything underneath dash cuz i gonna just go by new key ignition switch but ended up not having enough well i went to chevy house gor new kwy cut an did everything they told me an still wont start an lil car with lock symbol never goes off let sit with in on possion for 2hrs an still didny go off
Old 11-25-18, 09:52 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Do you need a chipped key?
Old 11-25-18, 10:05 AM
D
Received 45 Votes on 38 Posts
When you say it wont start the car. Are you saying the engine wont start & run or stay running?
Will the key go in the ignition ok?
Will the key turn the ignition?
Will the engine turn over or crank temporarily?
Will the key unlock the door(s)?
As Ray noted, you may need a key with a chip in it.
Now, you key saying; "Key with a little car & lock symbol". Ok, so did you get more than one key? Did one key start the car but the other key wont?
Old 11-25-18, 10:09 AM
B
Hey
Got a key with chip an yes unlock car go in igntion an turms it over jist wont start cuz anti theft
Old 11-25-18, 10:14 AM
D
Ahhh... ok, so you unplugged some things under the dash including the anti-theft device & now it wont start?
So, did you get the anti-theft device plugged back in ok?
If so, I am guessing its going to have to be reset by a computer code at the dealer. I don't know that but thats what I'm betting.
Hopefully someone else has idea's & or knowledge.
Good luck.
Old 11-25-18, 10:16 AM
B
Hey
It started for asec then shut off an i havent been able get it start since then
Old 11-25-18, 10:31 AM
Received 1,112 Votes on 1,032 Posts
The new chipped key must be learned into the car's computer. For you to do it..... you'll need one working key and the new key. If you don't have a working key then the new ones must be dealer programmed into the car.
Old 11-25-18, 11:07 AM
A
Received 18 Votes on 17 Posts
might try the 3 key cycles of 10 minutes each.
https://www.youtube.com/watch?v=PVrJWz-XZ1Y
Old 11-25-18, 12:04 PM
ukrbyk's Avatar
Received 11 Votes on 8 Posts
Your security system does not recognize the key.
This is why you have KEY symbol showing.
You need to do key learning procedure or have dealer mate key to computer.
Otherwise, you have fuel pump disabled.
We have no idea what and WHY you disconnected under the dash. You might as well messed something up.
