1999 toyota 4runner transmission not engage
Old 12-09-18, 05:37 PM
Old 12-09-18, 07:02 PM
Received 3,977 Upvotes on 3,569 Posts
Ok....... and......
We can't help you if that's all the information you can share with us.
Old 12-10-18, 03:16 PM
F
4wd
Make sure the 4 wheel drive transfer case is not in N (neutral) needs to be in high or low.
Any warning lights coming on?
Old 12-10-18, 05:22 PM
Hello gentleman's, I have a Toyota 4Runner 1999, 4WD. V6, 172K Mile,
last week i have noticed that when i come to stop sign or traffic light the gear is not engaging even though the car is in gear (D). the RPM goes up but car not moving. if i turn the car off, and wait for I would say for 2-3 minutes than turn the car back on and switch from Park to Drive the car is moving no problem, no grinding noise or anything, and if i am on highway getting speed no problem, as long the car is moving.
So it look like a some kind of electrical problem with maybe a solenoid that is not engaging.
I must point that about 2 years ago I had a blown radiator that needed to be change and some coolant got into the gear witch was washed and maybe 10K mailes later i am facing this problem.
need some help, Love my 4Runner (2nd Owner for the past 16 years).
thanks for any hint of how to fix this.
Old 12-10-18, 06:40 PM
Have you checked the trans fluid level ?
Needs to be done with it running in neutral on level ground.
If the trans fluid was contaminated..... there is no telling what could have happened.
Old 12-10-18, 07:47 PM
Good evening PJmax, Yes i did checked the level of the transmissions oil, while it was running in N.
I even added some oil, I went to my neighbor that is a mechanic at a Mercedes dealer, and he is saying to drop the oil pan and check the shift solenoids, there is also on you tube some video that talk about this. its about $40 on ebay a set of all 3 solenoids. Item number 153107569810.
I don't think that i have any problem with the 4WD. got to make sure that the gears engage first.
Thanks for your reply.
Sam
Old 12-11-18, 05:34 AM
the_tow_guy's Avatar
Received 251 Upvotes on 203 Posts
Before you start throwing parts have it checked for codes. Not sure on OBD2 Toyotas, but I don't think transmission codes always light the check engine light.
FWIW, I don't think it's going to be shift solenoids.
Old 12-11-18, 04:04 PM
Thanks the_tow_guy for your replying, I will check with that little toy to see if there is any code related to the problem I have.
thanks again.
