Is It OK To Fill A Dry Battery With DI Water Only?
Old 06-17-19, 06:40 AM
B
Received 1 Vote on 1 Post
My C240 has sat unused for the better part of a year, I found the battery was bone dry of any acid. There's nothing wrong with the car it's just rarely driven now. The bat. was getting discharged/or unable to hold a charge. Reason, popped the caps and found it had zilch bat. acid. Not even a drip, in any of the cells. Refilled with DI water and all cells test about 2ish volts. I don't want to give up on it yet. It's an AGM type about 3 years.
Question is I know we can refill with DI water when acid is running low but can it be filled with no acid but DI water only?
If I have to buy acid how much is needed to fill a 12v Group Size H8, 900 CCA battery?
Old 06-17-19, 07:19 AM
Received 106 Votes on 93 Posts
While I'n no expert on battery's , I've own several AGM battery's and not one had removeable caps, or had water in it.
Just a tiny vent on top.
https://lateral-g.net/agm-battery-maintenance-care/
bambata voted this post useful.
Old 06-17-19, 08:06 AM
Received 1,599 Votes on 1,473 Posts
The acid doesn't evaporate..... it's the water in the acid that you lose.
With the battery being dry for so long..... it may not come back to full capacity.
Old 06-17-19, 08:53 AM
B
OK. I added DI water and it's slow charging. Will see if it's bubbling in 12 hours
Old 06-18-19, 03:24 PM
B
Nothing happened, batt. is toast. Thanx for your ideas guys.
Old 06-18-19, 03:48 PM
The plates became sulfated and that's equivalent to a short across the plates.
