2003 Camry A/C Compressor Issue; not cooling
Old 07-19-19, 08:07 AM
B
Received 1 Upvote on 1 Post
I've had the Camry (4 Cyl, 2.4 L) to a local service center, where the A/C system was "basically" checked. The A/C system holds pressure with no sign of leaks, although the compressor clutch isn't engaging. I've come to the conclusion that either the compressor clutch is defective or I've got a wiring issue.
I'm relatively familiar with a Voltmeter/Multi-meter & would like to know if someone can tell me if there's a relatively straightforward way to check for voltage at the wiring harness connector, which connects to the clutch coil's wiring interface, to see if the compressor is actually getting power. The wiring harness connector, which connects to the clutch coil's wiring interface, consists of 3 wires (black/white, white/blue, & brown). If there's a device better than the Voltmeter for diagnosing, I'd like to know this as well.
Also, I've swapped out the Magnetic Clutch Relay with no success, although, I haven't checked the Relay socket to determine if it's getting power. Does the clutch coil connector get its power from the Relay or from another source?
Thanks
Old 07-19-19, 08:14 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
There is not much you are going to be able to do without a wiring schematic!
Old 07-19-19, 08:52 AM
B
Old 07-19-19, 11:43 PM
Received 3,922 Upvotes on 3,518 Posts
The black/white wire on the compressor needs 12v+ to activate the clutch. That voltage comes from the MG/CLT relay. The MG relay needs 12v+ on the blue line probably as soon as the key is turned on. The green/yellow wire gets grounded to activate the relay.
When you turn the A/C on..... do any of the fans start immediately ?
Name:  wire diagram - Copy.JPG
Old 07-20-19, 01:07 PM
B
Are you referring to the radiator cooling fans or the variable speed blower motor, which circulates heated as well as air-conditioned air within the Camry's cabin?
Old 07-20-19, 11:00 PM
Radiator fan. There are three fan relays shown in the diagram.
Not sure how many underhood fans there actually are.
Old 07-22-19, 06:00 PM
B
There are 2 cooling fans. Should one or both of them begin running immediately when the A/C button is activated? If one is a condenser fan, I assumed it would start when the condenser was experiencing an overheating situation, but since the compressor isn't engaging, how can the condenser overheat? Does the condenser fan have to start in order for the compressor to engage?
Old 07-22-19, 10:44 PM
No.... but typically at least one fan comes on when the A/C is turned on.
What did it do before ?
If a fan comes on as soon as A/C is turned on.... then the problem is out under the hood. Not an ECM problem.
Old 07-25-19, 04:13 PM
B
Thanks for replying. I believe my original post stated that a service center charged my system, which showed no leaks, meaning, the system had the required amount of refrigerant, so as to not enable a low pressure switch. At that time, they stated that "Your compressor is weak"; they too observed that the clutch wasn't engaging. I'm trying to rule out anything electrical, before I assume it's a clutch/compressor issue. Thanks again.
Old 07-25-19, 04:19 PM
B
This car belongs to my stepson, so I'm uncertain of normal operating behavior. I drove the car today & let it idle in the driveway for 15 minutes. Both radiator cooling fans turned on, so I know they're functional, although when the A/C button is engaged, no cooling fan response occurs.
Old 07-26-19, 06:02 AM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
I am wondering if the clutch wasn't engaging how they could have charged the system and stated the compressor was weak. Also, if there are no leaks, why would the system need charging?
Old 07-26-19, 07:44 PM
B
I'm no HVAC expert, so what you're saying, is that if the compressor clutch isn't engaging, a car's A/C system can't be checked, because the compressor isn't moving the refrigerant? My understanding was that the system was evacuated, determined to need some refrigerant, refrigerant was added & the pressure held steady. Had the clutch engaged & the compressor begun to move the refrigerant, I believe there would have been a swing in pressure, but eventually, both low & high pressures would have leveled off. If I'm incorrect, please correct me.
Old 08-05-19, 08:17 AM
B
2003 Camry A/C not ice cold
After several days of diagnostics, I addressed several issues. I replaced a leaking radiator & replaced a leaking Schrader valve. The compressor now functions, but not efficiently.
Being that the vehicle is 16 years old, I began an A/C rebuild. I replaced the compressor, condenser, & receiver/drier (bundled with the condenser). The A/C system is substantially better, but not ice cold. I've been avoiding replacing the Expansion Valve & Evaporator Core, due to the dashboard location, but will replace the components, if anyone feels that these components might be contributing to the lack of "ice cold" incoming air.
I've also replaced the cabin air filter, located behind the glove box, but didn't require disassembly of the dashboard.
Thanks
Old 08-05-19, 08:38 AM
A
Received 112 Upvotes on 97 Posts
did you pull a vacuum on the system prior to filling.
did you purge air from the manifold lines and fill the system to capacity?
Old 08-05-19, 09:11 AM
B
Yes. With the system completely discharged prior to my rebuild, I completed the rebuild. Then, I pulled a vacuum for a substantial amount of time, & then & only then, did I recharge the system, filling the system to capacity, based on the current temperature at the time of recharging.
Old 08-05-19, 09:27 AM
A
capacity is usually on a sticker under the hood, its going to be the same no matter what temp it is.
Old 08-05-19, 09:46 AM
B
The total refrigerant added was 1.4lbs, which coincides with what the information under the hood states. The pressures I read were in line with the current temperature.
