1993 Plymouth Grand Voyager: cooling fan problem
Old 09-05-19, 05:10 PM
B
1993 plymouth grand voyager fan is not running, overheats, replaced new fan motor and does not run, thinking it may be a relay, please educate me, could it be why the ac quit, thanks john
Old 09-06-19, 01:49 AM
A
Received 26 Votes on 25 Posts
would probably look at the relay and check for power to the relay think this is old enough that they was still using fusible links might pull on them and see if there burnt into.
would expect the a/c to blow hot air with no working cooling fan at a stop it may start cooling at faster speeds though due to the air flow throw the condenser pressure would be high probably a good idea not to use it until you fix the cooling fan issue.
Old 09-06-19, 03:35 AM
B
Received 111 Votes on 97 Posts
Check the fuse block cover to see if the fuses are identified. If fan and /or AC fuse identified, verify not open. If fuses aren't identified look for a blown fuse or check fuse continuity if you have a multimeter.
