2005 Camry LE 2.4
Old 09-30-19, 02:18 PM
D
2005 Camry LE 2.4
Could someone please let me know what that aluminum shield is called that is in front of the engine? It is as big as day. It is located between the block and the radiator. I've tried googling it and youtubing a diagram, but cannot find the name. Tks!
If I can find out what it is i can then find out how to remove it as it needs to be refinished.
Old 09-30-19, 03:41 PM
Received 1,324 Votes on 1,224 Posts
The metal that the radiator attaches to is the radiator support. Usually it's steel.
The only other thing is the A/C condenser that looks like a thinner radiator and the radiator itself.
Nothing could be completely solid as air needs to flow thru to the engine.
Old 09-30-19, 04:25 PM
the_tow_guy's Avatar
Received 62 Votes on 51 Posts
Only thing in that area like that would be the heat-shield on the exhaust manifold.
Old 09-30-19, 04:46 PM
D
Here is a video/picture....large 'v' shaped object.
https://youtu.be/7oE0sapNB5w?t=10
Old 09-30-19, 04:58 PM
Exhaust manifold heatshield.
Old 09-30-19, 09:32 PM
D
Thanks....The wire I see coming out of the heatshield is probably the upstream oxygen sensor? Can the heatshield be removed without taking the sensor out?
Old 09-30-19, 09:41 PM
The wire would be connected to the sensor with a plug.
On that vehicle..... it looks like there is a +/- 1' lead attached to the sensor with a plug at the end of the cable.
