Replacing an Infiniti thermostat
infiniti fx 35 2008 is running hot. i was thinking it's the thermasta
Thermostats are designed to run cold as they age and fail. When was the last time the cooling system was serviced? Is there coolant in the overflow and is the radiator full? Are the cooling fans working and is the front of the radiator clean so air can flow through? Do you get good heat in the vehicle?
