2003 Toyota Camry LE 3.0l AT Front motor mount
Old 11-02-19, 08:14 AM
I am replacing my 2003 Toyota Camry LE 3.0l Automatic Transmission engine and trans mounts. I bought aftermarket mounts and three (Top, Left and Right) went well. The front when i removed has a hose so i believe its vacuum controlled front mount. The aftermarket i bought says its compatible but does not have the hose and Now i am little concerned if i can install it or i should just buy the OEM part.
The part i bought is below
Engine Motor and Trans Mount Set of 4 for 2002-2006 Toyota Camry 3.0L with Automatic Transmission Engine Motor and Trans Mount Set of 4 for 2002-2006 Toyota Camry 3.0L with Automatic Transmission
Old 11-02-19, 11:50 AM
Hello All,
I just found the part as OEM. My question is do i need to use the vacuum controlled Front mount or I can just use the part i have without vacuum controlled. And I can close the hose tightly so there is no leak for the vacuum controlled mount.
The part i found is below
Toyota Part No.: 12360-0A080
INSULATOR ASSY, ENGINE MOUNTING, FRONT
