Impact Socket stuck on bolt (Lug)
I was replacing winter tires of my Toyota Corolla 2009 car, with newly bought Mastercraft Air Tools (Impact Wrench) and Maximum Impact Socket set.
I was using 13/16 socket (I also googled its correct size) and it was exact size (not loose at all), when i use this socket with impact wrench or hand torque wrench socket gets stuck very badly, each time i have to use hammer to hit the socket that makes it loose enough that i could take it out.
I'm not sure if Maximum socket size is not enough accurate or something else, any work around that can make it easy, i attached the image.
According to my research..... those are 21mm lugs. That would require a deep metric socket.
Size: M12 x 1.50. Hex Size: 21 mm. Seat Angle: 60 Deg.
would probably consider replacing the lug nuts they do get worn over time and causes the socket to turn more and stick to the nut, while it may be metric in my experience there really is little difference between the 21 and 13/16 the 21 would just fit a little looser and probably get stuck also.
Nuts are in good shape, that's really disappointing to know that they (Maximum) did not put all sizes in 150 pcs socket set. Can someone advise which socket set would be better choice in Canada, I will be using with air tools. thanks
You should not use impact tools for lug nuts, yes I realize everybody does, but as an ex-brake engineer for OEM you can warp rotors by over torquing lug nuts.
You should be using a torque wrench with proper torque, approx 100 ft lb, which is sufficient to keep wheels securely intact and low enough that you never need to use an impact tool to remove!
CasualJoe
voted this post useful.
Hit it with a hammer. Very common problem we ran into at tire shop. A little rust, wrong socket will do this. !3/16 = 21mm 3/4 = 19mm are very close.
I suggest tightening lug nuts manually with your hand halfway on the lug wrench handle.
Then if you have to change a tire on the road you should have no difficulty undoing the luig nuts iwht your hand all the way at the end of the lug wrench,
If you have to jump on the lug wrench to undo the nuts then the nuts are far too tight.
13/16 = 21mm 3/4 = 19mm are very close.
I snug them up with a ratchet then lower the vehicle just enough so the tire grips the ground, and finish them off with a torque wrench
"lower the tire so it just touches the ground, then lower the jack 5-clicks (yes, a bumper jack*) THEN tighten the lug nuts in a star pattern...
One difference, I was taught to always spin the lug nuts on by hand - if they DON'T spin freely, then you had to wire brush the stud and ream the nut with a battery terminal brush to clean off the threads...
*- if you had a tire-iron/jack-handle weight and placement JUST RIGHT
you could get the tire iron to bounce up and down,
basically the car would jack-itself-down to the ground for you
also amazed that using those wrenches is not safe because at workshops i saw them everywhere being used for this job
From the GM service procedures!
Improper wheel nut tightening can lead to brake pulsation and rotor damage. In order to avoid additional brake repairs, evenly tighten the wheel nuts to the proper torque specification
You dont get proper torque using a pneumatic gun!
they do make torque sticks for impacts so you do not overtighten them some shops use them but really if you just using the impact for a second to snug up the wheel follow up with a torque wrench never really had any issues.
if applying torque in the opposite direction loosens the socket on the nut its usually caused by wear on the nut really there not very expensive local parts store should have them in stock.
If 13/16 (0.812 thousandths) socket fits loose, a 21mm (0.840 thousandths) socket will even be looser. Using a micrometer or a digital vernier, measure distance across flats on lugs and get correct socket or get new lug nuts and socket that measure the same distance across flats.
I never saw it mentioned whether this was a 6 point or 12 point socket, I am assuming it was 12 point. Many years ago we always used 6 point sockets to remove lug nuts.
Most tire shops will require the tech to use a torque wrench to tighten lugs. they will run the lugs in with a air wrench and than lower car and go around car with torque wrench. One reason is for wheel off after working on car. Was a firing offence for us it not using torque wrench.
My tire shop changes my tires from standard to snow treads for me each year. I specify to them the manufactuers torque for these (120 ft pds) and they generally get it close but still is a bear to remove in an emergency, I bought a Milwaukee electric M18 and THAT gets the lugs off for me when I need it!
Where does it say to use 13/16" socket on Toyota wheel nuts ? It should be 21mm.
You are working with 10yr old rusted wheel nuts and that is the cause of the loose 21mm fit (I know, I live in Canada and the salt will rust a 21mm down to 19mm in 10yrs)
Get new nuts, get the right socket AND DON'T TIGHTEN THEM WITH THE IMPACT.
They put them on tight so that they do not fall off.
Better too tight than coming loose.
A good tire shop will torque them and then want you back in a couple days to check/re-torque them.
Personally I carry a 2.5 foot heavy wall pipe in the car as the little tire wrench they give you these days is inadequate to say the least.
Never had a tire I could not get off.
