2009 Ford Escape Ignition switch
Old 12-06-19, 10:43 AM
C
2009 Ford Escape V6, When I turn Key to start no crank. Note: Everything works in the car, All light are in good order, The only problem is when I turn the key to start position, nothing happen, no crank no start. once an a while after 7 to 10 times might start. I have a new key and I tried it and it also failed. The only time it start every time is when I push the key unit inward and turn the key at the same time to start position, it start no problem. My question is, what is happening ( or creating) when I push the key unit head in that make the car to start? am I improving grounding by pushing the key inward? if so how can it be fixed? Thanks in advance Censu.
Old 12-06-19, 12:40 PM
P
Received 8 Upvotes on 8 Posts
I had this happen with a Mazda 6 I used to have. It took the dealer over a week to figure it out, but it turned out to be the throttle body.
Old 12-06-19, 02:23 PM
Received 22 Upvotes on 17 Posts
I think you need a new ignition switch (and key)
https://www.google.ca/search?sxsrf=A...33.oB0LKIrz9cU
iceman681 voted this post useful.
Old 12-09-19, 10:43 AM
C
I just changed the switch only, will see if it hold. Thanks for the info!. Will be back if problem returns.
