Wiper fluid pump replacement issue
Old 12-08-19, 12:45 PM
C
I replaced an original Denso waist fluid pump on a 2008 Toyota Corolla. The Denso pump was split in half, no clue what caused it. I figured it would be a simple replacement job but it has not been the case.
- after putting in a Napa aftermarket pump, the pump rims but nothing came out of the wiper nozzles
- a returned that pump thinking it was a dud and put in another only to still have no fluid coming out of the nozzles
- I connected tried two new wiper fluid nozzles thinking they were clogged and that didnít work
- I connected the hose to one nozzle directly and got a spray but it was a puddle type of spray on the bottom of the windshield
I think itís one of 2 potential issues
- the original Denso pump generates more spray pressure than the aftermarket pump?
- the hose needs replacing? I see no holes or wear in the hose
anyone have any ideas or come across something similar?
Old 12-08-19, 02:49 PM
pugsl's Avatar
Received 76 Votes on 69 Posts
replace hoses and any connectors in line
Old 12-08-19, 03:30 PM
ukrbyk's Avatar
Received 16 Votes on 13 Posts
You need to work it out in staged manner - is there flow out of pump? Before the first connection? After connection? After T? And so on. Those pumps do not generate monstrous stream, not fire trucks. You have blockage somewhere.
Old 12-08-19, 04:07 PM
C
I have flow
I just donít know if itís enough flow. I tried it with no nozzles and the fluid is flowing in the hose....there is just no way to tell the strength of the flow
I add both new nozzles and nothing comes out of the nozzles l. I add one and it puddles out
think I will just pull the whole hose and replace it.
what are the odds of 2 bad aftermarket pumps?
Old 12-09-19, 06:22 AM
ukrbyk's Avatar
I had THREE bad alternators out the box in one night once. Al's Auto Supply. Store is no more anyway.
Maybe find OEM pump at a salvage yard?
Old 12-09-19, 06:04 PM
C
I was actually thinking about that last night, I will call the wrecker tomorrow and go that route if the hose replacement does not work
the only downside is that would be the third time I would have to get to the dang thing through the wheel well as itís inside the fender.
Old 12-10-19, 06:12 PM
ukrbyk's Avatar
I'd say, this time make it perfect. Disconnect hoses and run them from jumped pump. While it's OUTSIDE.
