2011 Toyota Sienna
Old 01-21-20, 02:04 PM
T
Red face 2011 Toyota Sienna
Hi Everyone,
I have 2011 Toyota Sienna the front driver seat has no power, so it's stuck I push on all the buttons & nothing happens not even a buzzing noise. I checked interior/exterior fuse box to see maybe the fuses are bad, but they are not. I coming to a conclusion that MAYBE the side buttons switch is bad? Any input will be gladly appreciated. Than you in advanced!!
Old 01-25-20, 08:01 AM
ukrbyk's Avatar
Received 12 Votes on 9 Posts
You need to remove the side panel and get to the switches, to check if you have power to them. There is not telling otherwise.
Old 01-25-20, 01:39 PM
Received 10 Votes on 7 Posts
There should be a plug under the seat.
You will need a schematic for that plug.
How did you check the fuses to be sure they are good?
Do you know which fuse feeds the power seat?
Old 01-25-20, 02:27 PM
D
Received 48 Votes on 41 Posts
I'm with 2 granddaughters.... back to the fuses. Fuses are cheap, dont just look at them. Either pull them out & test them or simply replace them to see if it works at that point.
Then go to the switch on the side of the seats.
(I'm betting on one of the two being bad.)
Then move down the line to the wiring harness plug/connector & check the power there.
Start one end & work your way back.
Old 01-27-20, 07:01 PM
T
2011 Toyota Sienna
Thank you, so much for all inputs. I have replaced old fuses with new and still nothing. I havenít removed the side panel to check the switch itself that will be next. Thank you.
