1995 Camry V6 LE Wagon Lose Coolant Slowly
Old 02-19-20, 04:10 PM
D
1995 Camry V6 LE Wagon 160K miles. Add coolant to "High" mark at reservoir when engine is cold. Coolant loss to almost at the "Low" mark after about 6-7 weeks. Inspect hoses and doesn't see any tracks of leaking. I am guessing it might be head gasket, but this car never been overheat before and has been running great. Any suggestions?
Old 02-19-20, 07:56 PM
iceman681's Avatar
Received 5 Votes on 4 Posts
replaced many water pumps for this, look right under the crank pulley for drops. the pump is in the timing cover. also could be the radiator end cap they crack and seep just enough to be burned off before you see in on the ground.
Old 02-20-20, 06:27 AM
Marq1's Avatar
Received 946 Votes on 859 Posts
If there is no coolant leak anywhere in/on/around the engine then head gasket leak is most likely, slow enough leak and you will never see or smell out of exhaust.
Checking the plugs for fouling, or the rad fluid for hydrocarbons (they sell a test kit) is next step.
Of course they sell repairs in a bottle, but who knows what else that stuff plugs up!
Old 02-20-20, 04:32 PM
D
Thanks for the replied. I will check when I get a chance.
Old 02-20-20, 06:25 PM
Received 18 Votes on 13 Posts
Have the system pressure tested.
The car dealers sell the bars-leaks tablets.
When I worked at Chrysler Canada they put them in the rads in the factory
