can voltage be measured to car speaker?
Old 04-09-20, 09:16 AM
K
I think I may have a broken wire going to the speaker in the door of my van. I was wondering if there is a measurable voltage going out to the speaker?
Thanks
Old 04-09-20, 09:30 AM
Received 756 Votes on 710 Posts
There is not a known voltage you could check for as the speaker is driven by a fluctuating AC voltage. You would need to use an ohmmeter to check from the speaker to the radio plug.
Old 04-09-20, 10:07 AM
K
Ok, thanks. That's kind of what I figured but wasn't sure.
Old 04-09-20, 12:56 PM
P
Received 444 Votes on 408 Posts
If you can disconnect the wires at both ends you can twist them together on one end then test for continuity on the other end. Or, you could tape the ends to a battery and check for voltage at the other end.
Old 04-09-20, 06:24 PM
Received 6 Votes on 5 Posts
The speaker may have gone open
Old 04-09-20, 07:36 PM
iceman681's Avatar
Received 3 Votes on 3 Posts
depends on how strong of a system you have. i used to run Christmas lights on an amp to where they would brighten with strong the bass
